| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Why not just drive it for a while and see what you think of it the way it is. Over time you'll discover something you'll wish you had and then tailor the mod to fit your needs.
As far a "lugging" your engine, don't worry about it unless it becomes a serious problem in your everyday use of the truck.
That SM420 is a rock crusher of a tranny and essentially a fully syncro 3-speed which should be totally adequate for daily use. Remember that these things came with 3-speeds that were only syncro in second and third. I have an SM420 in mine and wouldn't think of swapping it out. | | |
