I've fabricated replacement parts on a few heat risers. The big problem is replacing the bi-metal spring, if it's weak or broken. Sometimes an automatic choke spring can be substituted. Don't make the shaft clearance too close, as it's an open invitation to rusting solid again if there's not at least a little slop in there.
