| | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Try tapping firmly fore and aft on the shaft and weight. Keep the shaft wet with penetrating oil while you tap on it. You can hit pretty hard, but not like you are trying to drive the weight through the manifold. When the shaft moves a little, squirt more oil and tap in the other direction. Twisting the weight usually doesn't work until the whole thing begins moving. I haven't done the replacements you are thinking about, so no comment there.
Harvester | | |
