1 members (Hotrod Lincoln),
104
2
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 17 New Guy | | New Guy Joined: Jun 2008 Posts: 17 | I have a 1946 chevy half ton pickup that I'm restoring.It has a 216 straight six cylynder engine. Originally when I brought it home It had seized on me. I kept pooring marvel mystery oil down the cylinders,purchased a six volt battery and tryed to start it. It turned over but would not run. I have a mechanic friend working with me to try to start the engine. At first se thought it wasn't getting gas and it seemed like the fuel pump was gone. I ordered a new one through Jim carters online and replaced it. We tryed again and again it turned over but did not start.The end of the wire on the ignition lock was burned so my friend spliced a piecce on and I purchased new plugs (which I gapped according to the reproduction shop manual I ordered) and a new six volt coil.I put all of this on (i replaced one plug at a time so the wires would not get crossed.We tried to start it and still it turns over but wont start. Almost like its getting no spark. My friend took the coil wire off of the distributor snd ground it against the block. There was no spark.In my manual it makes mention of a reversing switch that according to the manual sits on the top of the starting motor that is essential for the primary current through the ignition system. When I look at my starter motor there is no switch there and no marks where something may have been mounted there.There are two wires on the distributor. One goes from onwe part of the distributor to the othere and the other wire goes from the distributor to the negative terminal on the coil. Every diagram i;ve seen references this switch when wiring but I don't have a trace of one. Does anyone have any ideas before my pride and joy becomes a glorified lawn ornament. | | |
