8 members (mvigo, Charles in CA, Rusted Nut, UtahYork, Peggy M, Shade Baby, klhansen, 1 invisible),
80
2
Mod | | | Forums66 Topics128,074 Posts1,055,913 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45169 09/03/2004 8:27 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I get about 16-18 with my 261 but only if I keep the timing advanced a few degrees. It's enough so it misses a little if you run the engine at fast idle (the vacuum advance kicked in) but at curb idle and under load it runs great. If I run it in the stock position I only get about 14. The engine is stock except for an auto choke rochester and a dual point distributor plate.
