7 members (55shaker, Bill Hanlon, JW51, JoergK., lumbersawyer, MickeyP, 1 invisible),
41
3
Mod | | | Forums66 Topics128,176 Posts1,057,121 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Emile;
Great looking Panel!
Are you sure it is a 1/2 Ton? It looks a little long to me and the rims a little big. If the wheel base is in the 137" range it may be a 3/4 or 1 Ton. The vin can tell.
I believe your cab will accept a gas tank and seat from the 41 -46 era. I put a bench seat from a 1/2 ton pick up in mine and it works great. You can actually install it to get a bit more leg room than usual.
Good luck with it.
Mike
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
