1 members (baldeagle),
100
6
Mod | | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44776 04/24/2003 2:57 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | does the vibs go away when you press the clutch? Could be clutch plate/pressure plate or drive line to. All the bolts the same in the flywheel? Same length/weight? | | |
