8 members (C10 - C90 Bill, Donf, DoubleB, Otto Skorzeny, Gdads51, Hanks custodian, Forty9, 1 invisible),
40
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,020 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Can I install the bell ,the 4 shims, and the fastening collar to check for proper adjustment with the tranny just lying on the floor and not mounted on the frame?Yes - follow the instructions in the Shop Manual for determining how many shims/gaskets are needed. http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0711.htmlAlso the inside of the bell is scarred up somewhat, probably too bad to smooth with emery paper. Will it be ok to use it anyway or should I try to find a ggod one? Maybe - Maybe not. It depends on how badly it is scarred and if the scars are near the cork seal on the retainer. If I need a better one where could I find one ?Jim Carter used to sell a reproduction bell/cover. He also sells used parts. You might want to call them. Or, post an ad in the Swap Meet. | | |
