| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44617 04/17/2002 10:12 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | A non full pressure is a dipper, babbit pounder, splashoil, low pressure, or non-insert (poured bearing) engine. Those are any 216 and the early low pressure 235. The later 235 was full pressure (insert bearings with drilled crank) but not full flow. Full flow means all the oil goes through the filter before it goes to the bearings. A bypass engine sends about 10% of the oil through the filter (if it exists) and back to the pan.
