1 members (RLB),
215
2
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44613 09/13/2003 8:14 PM | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | Yes, you do have to remove the distributor. The clamp that holds the distributor down and keeps it from turning is attached to the vacuum advance. The shop manual has a nice section on removing it. It tells you to turn the engine until the rotor is pointing perpendicularly out from the engine, then make a mark on the distributor housing where the rotor is. Then you can remove the distributor and know how to position the rotor when you put the distibutor back in. MIne came out very easily. And my new vacuum advance works !!
My dad always told me, "Don't force it, get a bigger hammer".
