| | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44484 01/17/2003 12:08 AM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Experiment with connecting your vac advance to ported or manifold vacuum and see which works best. Make sure your vac advance can is still good.
Some misguided mechanics, who are used to hacking on SBCs, will disconnect the vac advance and run the motor on full mechanical with lots of initial lead-in. Usually makes anything but a 327 race motor run like crap. Like your motor is runnin' 6 grand through the 1320 anyway. Recurve that distributor & check all vacuum lines, and it'll run better.
good luck
chip
OH, make sure the vacuum modulator from the TH350 is run to manifold vacuum.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
