| | | Forums66 Topics128,197 Posts1,057,261 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 30 Apprentice | | Apprentice Joined: Dec 2007 Posts: 30 | Cletis, I appreciate the quick response. I tried changing the brake switch connections around and I believe I have fixed the whole thing. The wire leading from the brake switch to the fuse box was yellow with one green stripe, so I assumed that was the battery side..turns out both wires from the brake switch were the same color and had the same green stripe. So reversing them gave me the fix. I had the tail light wire hooked to the battery post on the switch. The technician that wire the truck in 47 must have run short of a different color wire to run to the brake light. This is what makes this so much fun. | | |
