| | | Forums66 Topics128,018 Posts1,055,339 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | The rod should be straight. Bent rods bend easier than straight rods. I know someone will have a situation that used a bent rod and it worked for 100,000 miles, but I have never seen one. The rod should also be as short as possible. If it needs to be longer because of relocating the MC; the rod diameter needs to be larger than stock for added stiffness. | | |
