| | | Forums66 Topics128,153 Posts1,056,842 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 21 Apprentice | | Apprentice Joined: Dec 2007 Posts: 21 | One possibility is that your residual pressure valve in your master cylinder might have been leaking. When that happens, it allows the wheel cylinders to ingest air past the wheel cylinder cups. As for the master, yes, I believe that the flared end of both cups goes toward the outlet of the cylinder. Here's an exploded diagram: http://chevy.oldcarmanualproject.com/gmc/5559mm/5559mm175.html | | |
