| | | Forums66 Topics128,026 Posts1,055,410 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | regmudd,
The fuel gauge has been modified to work on a different volatge (12) but the resistance parameters are the same...0 to 30 ohms. Jim Carter has the matched sending units for the gauge as do many of the specialty suppliers. You just have to make sure it will fit into your 'Yogi' tank.
All the vendor has to know is that it's a sender out of an old Chevrolet truck...he should know it's a 0-30 unit.
You probably will not find something like this in a 'universal' configuration at your local auto part store. 0-90 is the common critter.
Stuart | | |
