| | | Forums66 Topics128,114 Posts1,056,613 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | 46 panel, Never tried to accomplish that but went and looked at mine. Maybe you could rig a steel rod though the hinge joint on side panels to slide like a barrel bolt into a drilled hole in the beltline. The holes wouldn't be visible until you opened the hood. As far as the replacement panels I made most of mine. Some panels can be found at old truck suppliers like Jim Carters/American/LMC?Dixie. Ray Stanley at Wheelwright Restorations could probably make if you can't find. By the way Welcome to the Bolt! Have fun and good luck Dan | | |
