Josiah, you got me confused. You said it's running trans fluid through an oil cooler "INSIDE" the radiator? I would think it's running radiator water around an oil cooler inside the tranny. I either need to have this radiator re-cored or buy a new one. If I buy a new one I will have to tap hole is it for the trans lines. Thanks
1964 Chevy C-10
