9 members (68ironhead, 3100RustyParts, Peggy M, DaveV, Joe H, Ridgeback, Gdads51, Nick in Manitou, dt235sd),
112
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,214 Posts1,057,486 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44054 05/05/2003 4:27 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | sswapp,
The nine inch seems to be plenty tough and there are LOTs of part available for it. The downside is that the wheel bolt pattern won't match the front on a Chevy pickemup. I put a '67 **** rear end under my '49 Chevy pickup for two reasons. 1. The wheel bolt pattern matches the Mopar front suspension and 2.) I already had the **** rear end that was the same width as the Chevy 12-bolt it replaced.
One other reason for the popularity may be because of the abiblity to quickly change gear ratios by just swapping the center section.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
