Rins better if you set it to total advance of 30 degrees or so . substantial increase in power and usually runs a bit cooler too .
This worked out to almost 10 BTDC in my 230 .
There should be _no_ vacuum coming down the advance pipe @ idle if all is well with your carby
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
