My local auto parts store had the correct (but not original) replacement. One good place to check out is Tractor Supply. Sometimes they have what the auto parts places don't.
Use an automotive belt. But more important, make sure you get the right size and length, then tension the belt properly--not too loose, but don't get it so tight that you mess up the bearings in the water pump or generator.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
