| | | Forums66 Topics128,162 Posts1,056,937 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43763 06/07/2004 3:13 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | For the dampener, you can use the one off the 216. You will probably need to get a redi-sleeve to put on the shaft where it seals, there is usually a groove cut in the shaft from the old seal.
Fred 52 3600 69 C-10
