| | | Forums66 Topics128,162 Posts1,057,049 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Loosen the fuel pump attaching bolts a couple of turns, and wobble the pump housing up and down an inch or so. If that produces better fuel flow, you might have camshaft problems. Also check the pressure and vacuum at the pump fittings. Will the engine run with a gravity-feed tank plumbed directly to the carburetor? Jerry
Entire Thread
216 - Squeaks when Cranking, negligible fuel flow
| Brendan M | 07/29/2008 3:13 AM |
Re: 216 - Squeaks when Cranking, negligible fuel flow
| doc bob | 07/29/2008 3:29 AM |
| crenwelge | 07/29/2008 3:34 AM |
| Hotrod Lincoln | 07/29/2008 3:38 AM |
| doc bob | 07/29/2008 4:11 AM |
| Brendan M | 07/30/2008 1:55 AM |
| Big Tee | 07/30/2008 6:52 PM |
| Brendan M | 07/31/2008 2:21 AM |
| krmitbug | 10/12/2008 1:34 PM |
| 31,32,33 | 10/12/2008 1:44 PM |
| neilroy | 10/13/2008 12:23 AM | |
