| | | Forums66 Topics128,162 Posts1,057,056 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | The squeaking may be totally unrelated to your problem, or it may be the fuel pump. Loosen the fuel line and see if you have fuel going to the pump. If not, look for a restriction in the petcock. That is a likely place for debris to settle. If you do have fuel at the pump, the fuel pump may have gone bad. If it is an old NOS, some of them will not stand up to today's fuel. While you have the pump is off, stick something, not your finger, like a dowell in the hole and see if the lobe is still there. A leaking fuel pump can squirt gas on the lobe and lose lubrication and wear quickly. If it is the fuel pump, buy a new one. | | | |
Entire Thread
216 - Squeaks when Cranking, negligible fuel flow
| Brendan M | 07/29/2008 3:13 AM |
Re: 216 - Squeaks when Cranking, negligible fuel flow
| doc bob | 07/29/2008 3:29 AM |
| crenwelge | 07/29/2008 3:34 AM |
| Hotrod Lincoln | 07/29/2008 3:38 AM |
| doc bob | 07/29/2008 4:11 AM |
| Brendan M | 07/30/2008 1:55 AM |
| Big Tee | 07/30/2008 6:52 PM |
| Brendan M | 07/31/2008 2:21 AM |
| krmitbug | 10/12/2008 1:34 PM |
| 31,32,33 | 10/12/2008 1:44 PM |
| neilroy | 10/13/2008 12:23 AM | |
