Just bought a 54 Chevy 3100 half ton truck. I haven't worked on one of these for forty years but I think it should run smoother than it does. It feels as though it has a fouled plug or wire but that is all new. The plugs are burning rich.
The following was done while in neutural and parked. It runs rough at any RPM and because of a possible bad accelerator pump it has a dead spot when accelerated.
It has the Hydra-matic transmission.
It has a B Rochester carburetor which appears to be recently rebuilt.
It has a new electronic ignition using Autolite 847 sparkplugs.
It was also converted to 12 volt and most of the wiring has been changed though pretty sloppy.
I plan on using this as a project and will make changes where needed but I would like to drive it for now.
Scott
[email protected]
Thank You
