The half inch belt (smaller) will work just fine. The balancer and water pump on the 57 will have the narrower pulleys. If you are using your old generator, you can swap out the pulley on it. Confused about the pulley diameter being smaller. Which pulley? If it's the water pump, you should put on a larger pulley.
Fred
52 3600
69 C-10
