Thanks for the info Dusty. I will look for the block # today. So the head seems to be a 235. I'm confused about one issue though. I was told that if the valve cover had two center bolts, as opposed to side bolts, then it's a 216. Which my valve cover does have the 2 center bolts. Was the information I recieved on the 2 center bolts not correct? Or is there some logical explaination about the two center bolts?
Thanks for the info, I'll piost again tonight when I find the other numbers.
