| | | Forums66 Topics128,193 Posts1,057,255 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | If you want originality, I would go with a 48-55 frame. There is hardly any similarity between 49 and 57 frames. It would be doable but it would be a lot of work to accomplish really nothing. I was cleaning up here a while back and gave several parts pickups away that had good frames. Also, a GMC and a Chev 1/2 ton frame are different. Get one that is a bolt together and save a lot of work even if you have to buy a parts truck for a couple of hundred. | | |
