| | | Forums66 Topics128,018 Posts1,055,339 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Dendo,
A charge voltage of 14.8 is still within normal high limits so I wouldn't worry about that. I would do as BC52 recommends and see what that meter attached to the battery reads when you do your little draw down test.
I don't know what kind of charging system a '63 has, but it might not be able to see system voltage well enough to react and kick in in short order. Your dash volt meter, however unlikely, could have a very poor connection to the charging system. If you compare a test meter reading at the battery with the dash gauge reading it should give you a direction to go.
If your rig uses a voltage regulator with either a 10dn alternator or a generator, I would be real suspicious of it.
I would also look at the brushes on either alternator or generator.
Stuart | | |
