| | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Do a search as this has been discussed alot...some have put the front section in first and then the rear and others ( including me )have done the opposite. Either way it is easier if you have someone help you.
Are you using the two piece cardboard or the one piece abs plastic? If cardboard, unroll it and let it sit in the sun for a few hours.
What do you have the glue for? none is needed. and what is the installation tool?? never seen one...
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | |
