I want to add more ground wires to my truck ( I.E. - body to frame ,frame to engine ,etc. ). Where can I purchase the appropriate cables or wires ? Does it have to be the braided type or can you use a regular wire such as 10 ga or ...? I'm having a problem with my charging system and have been told I have some bad grounds or insufficient grounds . Where can I get what I need ? Thanks !
