| | | Forums66 Topics128,109 Posts1,056,268 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I started the project Sunday and didn't have as good of luck as you did. The old tie rod ends were pretty frozen to the tie rod. I took the steering arms loose with the tie rod amd finally managed to get the old ends off. The instructions said to drill the backside to a depth of 1/16" using a 9/16" or a 5/8" drill bit. We used 5/8" which was still much smaller than the shaft of the ball stud. We used a drill press and drilled a little deeper than suggested and then pressed them out. After that, I learned that the pair of new style ends that I had on the shelf for a couple of years were both left side. I am about to get that squared away too. | | |
