I know this has been covered but I'm a little unsure if I need a smaller booster, 7inch or not. My exhuast pipes don't look to be a problem due to the routing I've used. The linkage from my patrick's saginaw shifter could be the problem. Any suggestions from fellow bolters would be appreciated. Now Brothers has their conversion on sale for $317. I would stick with the drum/drum so no prop valve, if that gives me more room. Thanks joethehuman
53 chevy 1/2 ton
