9 members (FishinToms53, Otto Skorzeny, Gray_Ghost, Wally / Montana, TooMany2count, 1955 1 Series, baldeagle, KEVINSKI, 1 invisible),
90
0
Mod | | | Forums66 Topics128,052 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Roll the engine over by hand (pull the spark plugs out first) and check the flywheel teeth for damage. If the starter pinion has been bottoming out in ther flywheel, it might have chewed up the flywheel gear. The way to check for proper starter pinion engagement is top spray-paint the starter gear teeth, install the starter, and crank the engine over several revolutions with the ignition disabled. A properly-shimmed starter will wear the paint off about 3/4 of the depth of the tooth. It should not bottom out in the flywheel! Jerry
