Hi Rayce, I'm pretty sure your glass will be flat and therefor left and right are the same.
Re;glass thickness,I got mine made up in 5mm Green tinted tempered glass,it's pretty close to the original thickness and came with all the relevant safety markings etc.
Laminated glass is a MUST for your front windshields but I would go for the tempered glass in the sides purely for longevity. It wont crack if you accidentally slam your door!Or de-laminate for that matter.
Jimmie D's right though,it might not be as expensive as you think to get them made locally!
More pix on Flickr.
