2 members (Jay R, Donf),
71
3
Mod | | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 23 New Guy | | New Guy Joined: Mar 2004 Posts: 23 | I had this same problem on my '55 first series. The sending unit is all steel tubing. Mine looked like a piece of round stock when I removed it. I used carb cleaner and a coat hanger wire to clean it out, then used compressed air. I removed the gas tank, and it had literally 5 gallons of sand a sludge in it. Then I took it and had it boiled out at a radiator shop. I put a 5/16 in line fuel filter in the fuel line before the fuel pump. Which is a good idea on any vehicle you are just starting to get running. That way, if I starved for fuel, I removed the filter, tapped out the junk in the inlet, put in back in and drove away!
Bryan Bauman
Entire Thread
Fuel problems, once again.
| jdl | 06/08/2008 11:05 PM |
Re: Fuel problems, once again.
| BIG CHEVY 3600 | 06/09/2008 12:55 AM |
| jdl | 06/09/2008 1:41 AM |
| Achipmunk | 06/09/2008 2:37 AM |
| atomarc | 06/09/2008 3:03 AM |
| jdl | 06/09/2008 3:18 AM |
| Czechman | 06/09/2008 12:32 PM |
| BIG CHEVY 3600 | 06/09/2008 3:49 PM |
| B Bauman | 06/09/2008 7:05 PM |
| jdl | 06/09/2008 7:48 PM |
| Czechman | 06/09/2008 10:20 PM |
| jdl | 06/09/2008 10:42 PM |
| Czechman | 06/09/2008 10:58 PM | |
