| | | Forums66 Topics128,264 Posts1,058,357 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 46 New Guy | | New Guy Joined: May 2007 Posts: 46 | Try double clutching when you go into second. And there is no need to rev the engine when you do. A little practice and you should get it......Find a safe place to practice. When sitting still with the motor running in first gear slowly release the clutch pedal. When you feel the clutch start to engage stop and push it back in a little bit. That is Approx how far you need to depress the clutch to shift while moving. By letting the peddle come back to the top between shifts you match the speed of the gears in the tranny to the speed of the road and engine. This should allow a quiet shift......Hope this helps.
It's easier to get older than it is to get wiser.
