| | | Forums66 Topics128,084 Posts1,056,083 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | www.kanolabs.comBest stuff on the market for freeing-up rusty engines! I buy it by the gallon for use around my shop. Pour a couple of ounces of Kroil into each of the cylinders through the spark plug holes, and let it sit for about 2 weeks. Yoy should be able to drain practically all the Kroil out of the oil pan by then and pour it back into the cylinders. After a couple of pour in/drain out cycles, the engine should move with some pry bar action on the flywheel. Also, remove the pushrods before you start turning the engine to prevent bending them in case a valve is stuck. Once the crankshaft turns freely, then work on each valve to free it up. Jerry
