| | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Funny that you mention it. I thought it was backwards from what others have described with so in Hutchinson KS at the ATHS show this weekend, I paid close attention to new filter kits. They were labeled Inlet on the side and outlet on the bottom which is what I thought was correct. The inlet will go go to oil pressure sending unit area and the outlet will be a gravity drain that goes just above the oil pan rail and drins into the pan. | | |
