| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,785 | The reversed 4th./5th. shift position is only on the "RTO" series transmissions, with 10th. gear overdrive. It's possible to change from direct drive high gear to overdrive by simply assembling the cluster gear differently. I've converted direct-drive transmissions to OD by swapping 2 gears on assembly. Jerry
