| | | Forums66 Topics128,196 Posts1,057,391 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The 6v starter will be OK as long as you take the 6v flywheel with the bellhousing (clutch housing).
"Is there a gasket that should have been there? It must have been apart before because there was blue sealant there, but no gasket. "
Are you asking about gaskets between the transmission and the bell-housing, the bell-housing and the block, and/or, between the halves of the u-joint housing? | | |
