The
uni struts worked perfectly. I did have to cut
small sections from that small retaining wall behind the seat. I also got a roll of
insulation from Lowes that looks like it will work well on the rear of the cab. I then covered it with some
carpet I got from autozone. I laid down a layer of jute padding on the floor then topped that with carpet from Oriellys. The carpet from Oriellys was a better quality than autozones. I laid the uni struts on top of the carpet then bolted the
seats down. I finished off the exposed sections of the struts with
carpet. I think it turned out well. I'm goin to buy a couple of more rolls of the autozone carpet for the headliner and maybe the doors. It's pretty thin so it should lay very well.
