1 members (Hotrod Lincoln),
104
2
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Well I went out to the garage in order to start the beast up and move it out so that I could start repairing the damage from the tree that fell crushing my garage. Then I noticed that the axle on the 52 1 ton is off center. Although I did not take out a measuring stick and drop a line it certainly looked that way. Now I had this discussion before about swapping out a ford rear end and people said there was a concern for the center axle vs the offset 9in. Were the axles off center? or should I believe that the axle was changed? Thoughts? | | |
