Hello -
I am prepping my frame for an IFS kit install (55 2nd series).
According to No Limit, I need to level the entire frame. I have it so that the bubble is dead on from front to back (both sides), the bubble is on the line from side to side in the engine bay, and the bubble is dead on side to side behind the cab.
I just measured and realized that the upper and bottom horizontal pieces of the frame rail run at different angles. (The mouth of the C shape reduces as it gets closer to the front cross member.)
I am leveling the top, isn't that the side I should be leveling?
Any thoughts?
Thanks!
Ross
