2 members (GRNHydra, Peggy M),
90
2
Mod | | | Forums66 Topics128,060 Posts1,055,837 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Eb,
I agree with what Tiny has said, but interpret your question a little differently. If the two speed switch is part of the fan/motor, then you would merely take the wire that plugs into the cigarette lighter and wire it into a switched connection somewhere.
Does a '63 have a fuse box? Are there one or two spare tabs that switched ON with the key. Couldn't you stick your fan on one of these.
I would guess you want this thing off when you turn the key OFF. However you decide to do it, make sure you have a proper fuse in the circuit.
Stuart | | |
