1 members (Hotrod Lincoln),
104
2
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40521 01/06/2004 10:38 PM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | The truck wrecking yard nearby did not have any 12-bolts and he has a lot of trucks in his yard. My 14-bolt rear axle came out of a 3/4 ton pickup I think. The ring gear is stamped with "4 89" which I assume means the gear was made in April 1989. No guarantee that the truck is an '89 though. I still need to find out exactly what truck this axle was pulled out of so that I can easily order stuff like brake shoes... you know how those parts counter guys are if you don't have the exact make and model. It is indeed a semi floating axle. Anyone familiar with those "conversion" u-joints? One of the websites I visited mentioned that it was NAPA part #447 but when I searched the NAPA website for that part, it sure wasn't a u-joint. A driveshaft place in San Antonio sells them for about $23. I may just fork over the $300 to have a complete 1350 u-joint style driveshaft fabricated and then I should never have to worry about anything past the transmission. | | |
