8 members (Wally / Montana, Gray_Ghost, Bill Hanlon, warlock, Wayne67vert, dt235sd, TexasA&M48Truck, 1 invisible),
62
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,724 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 38 | I am back! I got my 1951 3100 on the road thanks to the folks here. I got it to start and now stop after re-doing all the brakes and lines. Now I am on to fine tuning. The engine seems to suffer from a lot of valve noise so I want to adjust the valves. A loud ticking sound is evident but the engine runs smooth with no smoke. The engine is a 1958 235 what looks to be off a car with powerglide. I have done a lot of research on the boards so I only have one question. With hydrolic lifters I assume you set the lash @ zero, (after running the truck for 30 minutes) which means there is no gap between the rocker and the valve stem, correct? Then tighten 1/2 turn more? Is that correct? thanks yall!
1951 Chevy 3100 5 window with a 1958-60 235 and original 4 speed.
