| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40434 01/03/2004 5:22 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The 248 won't limit your highway speed, your rear-end gear ratio will. I know that the '54 hydramatic has the same low gears as the manual tranny trucks. I don't know about '55. Anyway, the 248 should be sufficient if you use a higher gear ratio. | | |
