| | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | I just replaced my 6 volt battery. I have cleaned the terminals and the connections for the battery cables. The engine cranks, but slowly and doesn't turn over fast enough to start. When I checked after cranking several times, the ground cable is very hot. I put a charger on the battery and it looks like it was discharged. Any suggestions? | | |
