justin kohut
Remember that the fuel pump lobe on the 292 cam is in the wrong position to be used in a 194/230/250 block, so by doing this swap You'll have to run an electric fuel pump. As for the carbs, try Clifford, in the inliners site there is their adress, I don't have it.
Alexandre Garcia
