| | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40311 01/06/2003 8:16 PM | Joined: Aug 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 127 | You definitely want the water heat. Haven't really heard the cons of summer use but it would seem that you would want it on then also.
I have an offy dual setup with water heat and I ran long tubes from thermostat all the way under the motor to the manifold then from manifold under the motor back to the heater. It seems to work fine and looks clean.
I have heard there is a thermostat housing that has an outlet on the carb side? Using that with stainless hard lines would be the ultimate setup. | | | |
Entire Thread
Water heat or non-water heat, that is the question
| 56picup | 01/04/2003 11:43 PM |
Re: Water heat or non-water heat, that is the question
| reo_guy | 01/05/2003 2:11 AM |
| 56picup | 01/05/2003 3:43 AM |
| ftyler | 01/05/2003 5:28 AM |
| reo_guy | 01/05/2003 6:04 AM |
| Fred T | 01/06/2003 2:57 AM |
Anonymous
| 01/06/2003 3:54 AM |
| tclederman | 01/06/2003 6:51 AM |
| 56picup | 01/06/2003 2:44 PM |
| Zeker6 | 01/06/2003 7:50 PM |
| 41ChevyTrucker | 01/06/2003 8:16 PM |
| tclederman | 01/06/2003 9:20 PM |
| sixpack | 01/06/2003 10:21 PM |
| 41ChevyTrucker | 01/07/2003 1:32 AM |
| sixpack | 01/07/2003 4:00 PM |
| 41ChevyTrucker | 01/07/2003 10:10 PM |
| sixpack | 01/09/2003 3:17 PM |
| ftyler | 01/10/2003 2:07 AM | |
